Lowering Questions.
Old Mar 30, 2001 | 03:57 PM
Timmys88Z's Avatar
Lowering Questions.
Ok here's the deal. I was just wondering if I can do a cheap (ghetto) lowering job on my Iroc until I actually rebuild the suspension and do it the right way.
I dont want to buy anything (dont have any cash). Now this may just be a plain stupid question (feel free to laugh if it is ).
Buut, can't you cut your springs to lower the car? I really know nothing about this. I also wouldn't want to do it if it will adversly affect my handling in some way.
I am just bored and thought I might be able to do that to at least improve the appearance of the car for the time being. I'd only want to lower the car a half inch to an inch tops.
Ok, let me have it.
Tim Currie
1988 Iroc-Z
-350
-T-Tops
-'Free' Mods
The Score 12/1 and 1 Tie
14.76 @ 91 mph (you figure it out?)
AIM TCurrie1
ICQ 67616089
"Steer with the rear wheels"
Old Mar 30, 2001 | 05:03 PM
RARE-ROC-Z's Avatar
yes that is true that you can cut your springs. it is not recomeneded. but it will be ok if you only cut a half of a coil. and it will drop your car about 1" or so. its a good mod. i guess.
and no one should flame you for this question. we all have times when we want to do something and dont have any money to do it so..
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 7.5" 10 Bolt 3.23gears
Bright Red Hardtop/ Grey Custom Interior
5,507 IROC's Hardtops/Ttops; 2,415 5.7L IROC's Produced in 1990
DAILY DRIVER: 1991 S10 2.5L/5SPD WITH CAMARO RIMS
Old Mar 30, 2001 | 05:58 PM
Timmys88Z's Avatar
Ok cool so I can do it with no problems.
Now how do i got about doing it?
Any tips on what to do or not to do?
Old Mar 31, 2001 | 03:50 PM
Timmys88Z's Avatar
top
Old Mar 31, 2001 | 05:50 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Use a grinder but make sure you stop and let the spring cool from time to time.(Never use a torch)THe other effect of cutting it would be raising its spring rate,So if you want better cornering this is good but if you want a softer ride then this not for you
Daz
Old Apr 1, 2001 | 05:51 PM
Timmys88Z's Avatar
I have to grind the **** off? Or use the grinder to cut it?
Old Apr 1, 2001 | 10:53 PM
Redbird's Avatar
Car: '87 Firebird
Engine: '89 Corvette L98, unstock
Axle/Gears: 3.23 posi
Use the grinder to cut it.
If you do use a grinder, do like Daz suggested and don't let the spring get too hot. It'll ruin the spring.
Another way to cut it is with a portable Ban Saw, or with a Sawz-all. Use an apropriate blade in either one, and it'll cut through real easy. Another benifit to using one of these is that it doesn't heat up the spring like a grinder does.
Redbird
Bayou Motorsports
87 Firebird-Daily Driver/Autocrosser
84 Z28-Full bore Autocross car
Delta Region SCCA
#00 C Prepared
amargari
Nov 10, 2015 02:09 PM
jbates346
Oct 21, 2015 01:50 PM
327IROC85
Sep 23, 2015 12:11 AM
apie2546
Sep 20, 2015 01:03 PM
