why does my car ride like this
Old Apr 1, 2001 | 09:22 AM
zee28's Avatar
Car: 86 iroc
it feels like I have picked up a bunch of little pebbles in my tread.It never rides smooth,not a bad vibration,but im sick of it.The tires have been balanced,the susp. rebuilt and alighned.I dont have new shocks or struts,but have been told these are ok?Could it just be a bad tire.and if so will I have to switch all four to tell?
~mike~86 IROC-Z
Old Apr 2, 2001 | 12:43 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
It could be the driveshaft is unbalanced. I've had my rear end rebuilt, new tires (balanced very well too), rebuilt the front suspension, and I still have a driveline vibration between 75 and 85 mph. Above and below those speeds, it disappears. It's even causing some minor spark knock from what I can tell since it only happens in 3rd gear.
Greg Westphal
'87 IROC 305TPI/A4
Old Apr 2, 2001 | 01:16 PM
82camaro's Avatar
Car: 82 camaro SC
"pebbles in the tread" Maybe a bearing is on it's way out.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Apr 2, 2001 | 06:23 PM
zee28's Avatar
Car: 86 iroc
replaced both front bearings.could it be a rear wheel bearing?never thought about the driveshaft,but it does it at any speed over 15-20 mph,even under this it feels like im on gravel instead of pavement.thanks
~mike~86 IROC-Z
Old Apr 2, 2001 | 09:27 PM
82camaro's Avatar
Car: 82 camaro SC
axle bearings, pinion bearing, carrier bearings are all possible.
82camaro
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
