Eibach/Hotchkis/Other Spring Choices
Old Apr 1, 2001 | 05:42 PM
RoadRacin85Z's Avatar
Hey guys -
I was just wondering what you alls opinion is on spring choice. I'm trying to set the car up for road racing and AutoXing, and was looking over my spring choices.
Ok, so there's the Eibach Pro Kit which I see a lot of you have picked. There's also the Sportline springs, that lower it a little bit more. I don't mind going lower, but is the handling really any better? I don't like the fact that they're progressive rate, I'd rather have a constant rate spring. Any ideas there?
And there's also the Hotchkis, which one of my friends has, and swears by them...
Also, any other springs out there you guys would suggest??
-Joel Likness
- 84 Z28 In Progress
Road Racer
- 85 S10 350/350
Drag Racer
- 85 Nissan 200SX (yes, it's Japanese)
Circle Track Car
- 91 Lumina 3.1 Euro
Daily Driver
Old Apr 1, 2001 | 06:01 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
I have Eibach Sportlines and I have no complaints. I'm not an autocrosser so I'm not sure exactly what to tell you. After I switched to aluminum heads the front of my car gained some ride height and I was looking to drop it down - the sportlines did the trick.
Old Apr 1, 2001 | 07:31 PM
How much did it lower it by? I don't really want to go lower than 2", but the ad says 1.5 to 2 3/4". Thanks
-Joel Likness
Road Racer
- 85 S10 350/350
Drag Racer
Circle Track Car
Daily Driver
Old Apr 1, 2001 | 10:19 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
I've got the Pro-Kit, and am very happy with the results.
Old Apr 2, 2001 | 06:50 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
The Sportlines dropped mine 2" up front and 1.5" in the rear. With regular shocks and struts the ride is comparable to the stock WS6. Be careful concerning ground clearance though.
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,high flow cat,SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit and torque arm,MacEwen White face gauges,84 T/A cold air induction air cleaner,Grant Formula GT wheel.
Old Apr 2, 2001 | 11:59 AM
Hey Mongoose -
I also noticed that you have the SSM subframe connectors. I was thinking about running those, how do you like them? I'm also thinking about some sort of cross brace connecting the right and left side subframe connectors, I've seen it on a couple cars...
I really like that setup that you've got, though. I've got Tokicos on my race car, and have been very impressed with them. Also, I see that you're from Monroe, NC. Do you do any AutoXing around in the area? I'm from Durham...
-Joel Likness
Road Racer
- 85 S10 350/350
Drag Racer
Circle Track Car
Daily Driver
Old Apr 4, 2001 | 02:27 PM
dnovotny's Avatar
Well, I've tried the Hotchkis springs, and now I have Global West springs. So, I went from variable to non-variable. Bottom line, the GW springs are much easier to go fast with. You go over a bumb everyday, and the variable springs will react differently every time. You just can't have as much confidence in them.
Dave '91 GTA, '91 T/A
'91 T/A Mods: KB SFCs and lower chassis brace, GW Front Control Arm Del-A-Lum bushings, steering brace, rear control arms and panhard bar, PST poly-graphite bushings, Spohn Torque arm, Hotchkis STB, Bilstein shocks/struts, GW springs fr. 640lb/in, rr. 160 lb/in
'91 GTA Mods: GW SFCs and IRS/Alston SFCs
(Just bought it, mods have just begun)
Old Apr 4, 2001 | 04:39 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
i bought edelbrock springs about 2 yrs ago and put them in last summer. lowered the car about 1-1.5 inches. much better handling
91 camaro RS
- 305 TBI
Mods: Performer tbi intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo, accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edolbrock springs, KYB struts and shocks
Soon to come . Posi 323 rear end , aftermarket LCA,s and panhard bar , Ascd ram air hood, Z28 spoiler and grille , white guage faces.
MrPackstin
Oct 25, 2017 08:09 PM
gixxer92
May 18, 2017 11:20 AM
darwinprice
17
Oct 11, 2015 11:51 PM
tcflint
Sep 27, 2015 05:58 PM
Dragonsys
Sep 25, 2015 03:51 PM
