BAD VIBRATIONS---HELP!
Old Apr 4, 2001 | 12:32 PM
Bulldog92's Avatar
Car: '92 Camaro RS
Engine: 350 H.O.
Axle/Gears: 3.73 posi
I'm sorta at a loss here, so I need some help. My car is vibrating and I don't know why. I still had the original tires on my car (about 10 years old), so I thought it was the tires. I replaced them and the vibration is still there. The guys at the tire shop said that the wheels weren't bent, either. I've already had an alignment, too. The vibration kinda comes and goes. I don't feel it through the steering wheel, so I don't believe it's in the front wheels. I can feel it more at about 50 mph and it starts shaking somewhat violently at around 75 or 80.
I just got through reading some of the previous posts by people that had bad vibes and it looks like this may be a driveshaft problem...what does everyone think? I was talking to somebody the other day and he basically said "if it turns, it could be a problem". He had a vibration that he couldn't get rid of, but he eventually found out that his engine crankshaft was way out of balance. I read that somebody had a checklist or something for isolating vibrations...could you help me out here? Thanks.
1992 Camaro RS
305 TBI, 5-Speed
K & N open element, Hooker cat-back exhaust,
SplitFire plugs, Moroso Blue Max wires,
Macewen white-face gauge overlays
http://www13.brinkster.com/scbaeb/camaro.html
scbaeb@hotmail.com
Old Apr 4, 2001 | 01:29 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I had an A/C compressor go bad on me (the bearings were shot) that caused a really bad vibration on the highway, especially above 70 mph or so. I took the belt off ('87 with multiple V-belts) and it disappeared. I had the compressor replaced (converted to R134a at the same time) and that took care of it.
However, I have a vibration of a different kind, not engine-related from what I can tell. I'm pretty sure it's the driveshaft since my tranny and rear end have been totally rebuilt and it's only at 75-85 mph, not below or above those speeds. To see if you have an engine or driveline problem, put your tranny in neutral when you get the vibration and see if it goes away. If it does, it's engine-related. If not, then it's something else (driveshaft, rear end, wheels/tires).
Greg Westphal
'87 IROC 305TPI/A4
Old Apr 4, 2001 | 05:09 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
Could be the Harmonic Balancer, or the Drive Shaft.
Carburated 5-speed
Vortec heads,1.6 roller rockers, .480 Crane cam,T-5,355 4-bolt, 3.73 posi
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
