Squealing noise from left front tire (not brake squeal)
Old Apr 4, 2001 | 03:35 PM
Third's Avatar
I'm getting this squealing sound from my driver's side tire area. It sounds like brake squeal but my brakes were recently replaced. It's not my rotors either because they are not getting cut or grooved. What could it be?
Old Apr 5, 2001 | 07:32 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Several things. If it is a high pitched screech, it may be the wear sensor on your brake pads. You may also have an alignment problem (but this would give a VERY noticeable pull.....) Also, could be your wheel bearings are dry.... See if you can find which side it is coming from, and pull it apart for inspection.
Good Luck.
Old Apr 5, 2001 | 09:00 AM
Third's Avatar
Thanks for the info. It's definitely coming from the driver's side front tire and I can also hear it when the car is just sitting (turned off) and I rock it or nudge it. It's very annoying. I am going to get an alignment cause it does pull although not very much.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
B_Dubya
Aug 26, 2015 05:09 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
