2 Piston Calipers on an 84?
Old Apr 15, 2001 | 05:05 PM
NightHawk's Avatar
I own an 84 TA 4bbl HO. I was thinking of doing a break upgrade. I was wondering if it was possible to install 2 piston calipers on my front disks? If so, where can I get them, and what all do I need? Thanks for any replies.
Old Apr 15, 2001 | 07:41 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yes you can, this is the famous "1LE" converstion. A number of members here have done the swap, I'm currently in the middle of doing mine. Search the board for more information, or try these to start:
http://www.isthq.com/~dan/1LEbrake.html
https://www.thirdgen.org/newdesign/tech/brakes2.shtml
https://www.thirdgen.org/messgboard/...ML/001393.html
http://www.geocities.com/rgades/1LE.html
https://www.thirdgen.org/messgboard/...ML/001547.html
https://www.thirdgen.org/messgboard/...ML/001248.html
1984 Camaro Z28 Astral Silver w/ 2 1/2" cowl induction hood
Engine: Decked 385 cid 4 bolt w/ oil cooler, 9.6:1 compression, ARP fasteners, 600 cfm Performer carburetor, Torker II intake, Performer RPM Heads, XE268H cam, Magnum roller tip rockers, MSD6AL ignition, Blaster2 coil, recurved HEI distributor
Exhaust: Terminator headers, 3" stainless exhaust, Twister muffler
Transmission: 4L60 w/ police governor, Corvette servo, .500 boost valve, TransGo 700-2, 7-CS & 700-PKH, High-Energy frictions & bands, 2400 RPM torque converter
Drivetrain: 3.54:1 limited-slip Dana 44, Aluminum driveshaft
Suspension: BZW/NNN springs, 36mm/24mm swaybars & wonderbar, Spohn SFC's, panhard, LCA's, antisquat brackets, torque arm, poly bushings
Brakes: Front 1LE conversion in progress, Rear discs
Tires: Front P225/50VR15 Rear P265/50VR15
Because you can always sleep in your car, but you can't drive your house.
Old Apr 15, 2001 | 09:20 PM
NightHawk's Avatar
I got 15 inch rims though... could it still work?
Old Apr 15, 2001 | 10:39 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I hope so, I'm doing it inside my 15" z28 rims. ANDYZ28 has completed the swap inside a set of 15" RS rims, so I'm confident its possible.
Old Apr 16, 2001 | 05:31 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I have a set of stock GM '89RS rims on my 1LE mod '82 Z28. They clear very nicely.
Thanx,ANDYZ28
82Z 305 w/comp 270 magnum cam,Edelbrock Performer RPM,Holly 1850-4,serpentine belt drive.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
Old Apr 16, 2001 | 12:33 PM
NightHawk's Avatar
I just put new rotors (11in) on less than a year ago... do I really have to replace them too (to 12's)?
Old Apr 16, 2001 | 01:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Your rotors should be closer to 10 1/2", but yes, you'll have to replace them.
Old Apr 16, 2001 | 07:14 PM
ANDYZ28's Avatar
Car: 1982 Z-28
NIGHTHAWK, If you will se the other posts,and
go to our (ANDYZ28&jayg) web page.You will see the big difference in the rotors. Stock vs 1LE. Thanx,ANDYZ28
Old Apr 16, 2001 | 09:35 PM
NightHawk's Avatar
Well, as long as the new rotors fit... I guess I got no choice. Thanks for all the info.
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
the_hamturdler
Sep 30, 2015 12:50 PM
