changing drum brakes to disk...
Old Apr 23, 2001 | 10:29 PM
SkyF41's Avatar
can i change my rear drum brakes into disk brakes? and if i can what do i have to do to change them?thanks.
Old Apr 23, 2001 | 11:58 PM
Zac's92's Avatar
You need to get a new rear end the axle tube ends are different. I supose you could weld new ends on your old rear end.
Zac Spalding
Old Apr 25, 2001 | 05:36 AM
Dan W's Avatar
When I did my 9" swap I went with a set of aftermarket units from a company called TSM. The kit uses an 11" rotor. I'm pretty sure they make a kit for drum braked thirdgen rears. They will sell just the brackets if you want or a whole kit. Calipers with emergency brake provisions are available. Total cost for the kit I have was less than $300.
TSM, 9635 Hwy. 85, #8, Littleton, CO 80125, 303/688-6882
1988 T/A,
9" Ford, 3.50 gears, Auburn posi, 700r4 -w- 2100 converter, 360ci, 9.8:1 cr,
AFR 195 Heads, Weiand #7525 intake, Lunati roller 219/227, .479/.480, 112 LSA
Holley 700cfm 4bbl on TBI truck 7747 computer and chip by Howell-EFI
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
johanlindgren
Aug 16, 2015 12:16 AM
