Disk brake retro's
Old Apr 23, 2001 | 05:40 PM
mphmilkman's Avatar
Disk brake retro's
I have an 85 Z28 with a 7.5 10 bolt ring gear. It has drum brakes. I have the rotors, plates, and calipers from a 7.5 10 bolt disk rear. I know I will have to modify my mounting flange for the bolt pattern and would like to find out if I will have any other problems with it as well. I have extensive tools and can get just about anything done with help from a machinist. Help would be appreciated thank you, Mike
Old Apr 23, 2001 | 08:30 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
you will need the end of your axle turned down to fit inside the rotor. if the calipers are 84 and up they should fit fine. you should replace the brake lines and hoses and also the parking brake cables.
Old Apr 23, 2001 | 08:56 PM
mphmilkman's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 88 350 tpi formula:
you will need the end of your axle turned down to fit inside the rotor. if the calipers are 84 and up they should fit fine. you should replace the brake lines and hoses and also the parking brake cables.</font>
Thank you for the info and I did plan to do all new hoses and cables. I will send the axles out to be turned.......Mike.
Old Apr 25, 2001 | 05:37 AM
Dan W's Avatar
When I did my 9" swap I went with a set of aftermarket units from a company called TSM. The kit uses an 11" rotor. I'm pretty sure they make a kit for drum braked thirdgen rears. They will sell just the brackets if you want or a whole kit. Calipers with emergency brake provisions are available. Total cost for the kit I have was less than $300.
TSM, 9635 Hwy. 85, #8, Littleton, CO 80125, 303/688-6882
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
