Odd front end problem
Old Apr 24, 2001 | 09:21 PM
Robbie-85Camaro305's Avatar
Car: 1985 Camaro Sport Coupe
Engine: 305H
I have a 85 Camaro, Spt Cpe model. While driving around 30-40 mph the steering wheel is moving like I am turning it left to right and right to left. I got under the car while someone turned the wheel and it looks like the sway bar is staying put and the frame is moving. I am going to bring it to a chasis shop very soon. Anyone ever experience this?
Robbie-Metairie, LA
1985 Camaro Spt Cpe 305H
1997 Camaro SS
Old Apr 26, 2001 | 05:13 PM
nestz28's Avatar
It sounds like you have a crack in your frame where the steering box bolts on, a few other people have had this problem. If that's what it is you need to get the frame welded where the crack is. A good way to prevent this problem from happening again is to install a wonderbar from an IROC. It bolts on where the sway bar bolts to the frame and tightens that area to prevent flexing.
Old Apr 26, 2001 | 08:05 PM
robbob's Avatar
I had the same problem in my Camaro that I used to have.the crack was in the frame by the steering box.The odd thing was that my steering was fine and tight,I only found out when I went in for a wheel alingment.
Old Apr 26, 2001 | 10:03 PM
Engine: 305H
Thanks for the tips. I think I will be bringing it to the chasis shop this Monday, it feels to be getting worse. Is the wonderbar a stock item on the IROC? Depending on the price of the repair I am considering 16" IROC wheels. I may have them install an IROC steering box while they are in there. I have been told it has a different steering ratio for the wider tires. Robbie
Ghettobird52
Jul 5, 2024 11:18 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
bellez77
Sep 5, 2015 08:39 PM
draco
Mid-West Region
Aug 10, 2015 09:18 PM
