Parking Brake Adjustment
Old Apr 25, 2001 | 01:14 PM
BadBowTie's Avatar
OK, I know where to make the adjustment, and how to make the adjustment. Anyone here come up with an effective method of getting to the adjuster? I can get a wrench on the lock nut, but I can't turn it enough to break it loose. (the driveshaft and torque arm are in the way)
'86 Camaro SC 2.8 V6, 5spd, T-Tops
Bone Stock, except for:
(Performance)
Flowmaster cat back exhaust
(Non-Performance)
Pioneer DEH-P4000 head unit
Pioneer 6X9 Tri-Ax speakers
Jensen 8" dual voice coil sub
Blacked out tail lights and side markers (VHT
Nightshades spray tint)
(Hopefully these lists will grow quickly)
I like to think of it as a empty canvas
Old Apr 26, 2001 | 09:03 AM
Jza's Avatar
Jza
Remove the driveshaft. It's 4 very easy bolts, and the yoke slips out of the tailshaft. Take you maybe 5 minutes out of your way.
Old Apr 26, 2001 | 09:07 AM
Ken88GTA's Avatar
Air Ratchet! Or what Jza said!
Old Apr 26, 2001 | 09:30 AM
BadBowTie's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Jza:
Remove the driveshaft. It's 4 very easy bolts, and the yoke slips out of the tailshaft. Take you maybe 5 minutes out of your way.</font>
I had considered removing the driveshaft, just wanted to get some imput before I started disassembling things Not having a parking brake is driving my nuts.
(Performance)
(Non-Performance)
Old Apr 27, 2001 | 11:44 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
You don't have to remove the spline from the tranny (it will keep you from spilling some tranny fluid). Just remove the 4 bolts at the u-joint and let the driveshaft hang down. Then use a small vise grips and a wrench.
90 RS Convertible
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
