Subframe Connector Installation question
Old Apr 25, 2001 | 12:09 PM
indy82tx's Avatar
Car: 1982 Z28 Indy Pace Car
Engine: 305 LU5
When installing subframe connectors, do I need to have the car supported on its wheels (i.e. does this require a lift)? Can this be done properly with the car supported on jack stands? I don't want to preload the chassis while installing the SFCs.
Old Apr 25, 2001 | 12:30 PM
scauffiel's Avatar
It has to be on the wheels, as it would sit naturally. Otherwise you end up with problems like doors not closing properly and the car is "pre-stressed" because you welded it into a certain "bent" position.
There... Now that that is perfectly clear...
Steve
Steve's Trans Am Temple
Old Apr 25, 2001 | 06:14 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
As long as the suspension is loaded, does it matter how?
JamesC
Old Apr 25, 2001 | 07:07 PM
ede's Avatar
ede
when i made mine i took some readings with an angle finder when the car was parked on a known level surface (patio). then in the garage i put jack stands under the rear axle and the front control arms. used 1/2" ply wood for shims under the jack stand to get the same readings i had sitting on the patio. made the SFCs and welded them on and everything works fine.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 28, 2001 | 09:25 AM
LILRED383's Avatar
I recently talked to a tech at Global West, and they said that if at all possible,you should have them installed with the car loaded and with the driver(weight)in the drivers seat. Right now, my motors' out of the car(I'm installing a 383 roller w/ about 500 h.p.),so before I Start my engine after the installation, I'm going to install the sub frame connectors. With all the horror stories about stress cracks from chassis flex,I'm not gonna take any chances.
92 Camaro RS
Currently swaping over to a 383 stroker with a roller ste up, Fast Burn Heads , LT4 Hot Cam. Complete restoration in progress.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
