Car is creaking
Old Jul 23, 2010 | 09:57 PM
ricksvt's Avatar
Car is creaking
I am new to this car. Its a 1991 RS T-Tops. Whenever I hit a bump in the road, the car is creaking. Is there anything to do about this? I am guessing that its a common issue, but I dont know. Thanks for the help all.
Rick
Old Jul 24, 2010 | 07:14 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Car is creaking
Rick
SFC's (sub frame connectors) will help. They are not a 100% cureall but you will notice improvement in body stiffness.
Old Jul 24, 2010 | 09:38 PM
ricksvt's Avatar
Re: Car is creaking
It sounds like its coming from the door area, and or by the front suspension. Any other ideas?
Rick
Old Jul 25, 2010 | 12:45 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Car is creaking
Probably needs a suspension rebuild - let's face it, it's almost 20 years old. Start with tie rod ends and ball joints. Replace idler arm and maybe center link. Check the A-arm bushings and replace if cracked and brittle. Replace sway bar bushings and end links. And definitely get the "wonderbar" from a JY IROC or order from TDS (www.top-downsolutions.com). That will chew up $500 real quick, but can all be done in the driveway in a weekend. Then you'll need to look at new springs and shocks/struts. Oh, and if the A-Arm bushings look like they need replaced, save that part of the job until you get springs and struts/shocks - no sense taking A-arms down twice.
SFC's are nice, and a great chassis asset to these unibody cars - but won't do you much good if they are installed on a bad suspension - you'll just be putting them in while the car is off keel, and when the suspension is done it will end up remaining off keel since they have to be installed when the car is on the wheels.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
