Rebuilding Rear PBR Calipers...
Old May 7, 2001 | 04:36 PM
MikeDwhoROCZImports's Avatar
Any one here ever done it? My left driver side rotor is frozen, so everytime I would break it would pull HARD to the passenger side. I ordered a rebuild kit, and was wondering how you get the rubber between the piston and the brake pad off? Anyone have any diagrams or anything? Any tips? Any help is appreciated.
Thanks for the help in advance guys.
Old May 9, 2001 | 12:15 PM
bttt
Old May 9, 2001 | 06:53 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I am not sure what you mean with rubber on there. but, It is listed in my manual how to dissasemble them. it is bassically the same as the single pistion lay a clean rag on the inside to catch the pistions and blow air in where the hose goes and they pop out. it also says that if one comes out but not the other remove the dust boot from the one that did and slid it back in its bore till it seals and hold that one till the other comes out.
If my scanners power cord would show up I could scan the pages for you.
hectre13
Dec 11, 2023 08:14 AM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
