Broke a Spohn Torque Arm
Old Jul 24, 2010 | 12:12 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
So I was at the track last night and on the 3rd run I seemed to have broken my so called "bullet-proof" transmission mounted torque arm
I had a total of 6 runs on the thing with 60' on average about 1.83s with one run in the 1.6s, nothing really to call home to mommy about.
Looks like it failed on the weld as you will see in the pic's. Not sure how I'll go about fixing this and making it stronger, maybe I'll have it welded up again and then have another tube welded over top to give it more rigidity.
Old Jul 24, 2010 | 12:20 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: Broke a Spohn Torque Arm
that sucks.
Old Jul 24, 2010 | 12:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
it happens
Old Jul 24, 2010 | 01:57 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
See if Spohn will stand behind their work. Otherwise, weld it back up, just do it right this time.
Old Jul 24, 2010 | 03:27 PM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
I agree, contact Steve Spohn and see what he suggests. That sucks!
Old Jul 24, 2010 | 06:59 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Wow that sucks. I would absolutely call them and tell them about it. That broke so perfectly clean it was because of a bad weld (almost looks like no weld).
Old Jul 25, 2010 | 01:02 AM
EvilCartman's Avatar
Car: '82 Z28
Looks like a very crappy weld, no penetration at all. My torque arm has been in the car for a few years and many trips down the 1/4 mile, no failures yet.
Old Jul 25, 2010 | 01:05 AM
Tony89GTA's Avatar
Car: 89 GTA
Yeah maybe I'll give them a call just dought anyone would warranty something like this.
Looking at the break there is 1mm of penetration on the weld, I can see why it would snap with any type of shock to it.
You guys think my LINCOLN POWER MIG 180C will be enough to fix it up, just got it little while ago still learning how to weld lol.
Old Jul 25, 2010 | 03:18 AM
Twin_Turbo's Avatar
There is absolutely no penetration to that weld. The weld bead is still lying on there like caulk rope. is this stuff TIG welded or mig welded and ground down since it looks so smooth on the outside?
The way to fix it is to grind the weld bead off the tube and clean up the threaded insert. Drill a new prop weld hole and use TIG to weld it, make sure you get full penetration in this sucker.
Old Jul 25, 2010 | 03:34 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I would contact them. They may want to take a look at it to see if it's a fluke or if others are like it. Also, if that weld is bad you don't know if the other one is the same or not.
Old Jul 25, 2010 | 09:10 AM
built91Z28's Avatar
If they wont warranty it, I think the MIG welder will be fine for it. The biggest thing is going to be to practice A LOT before doing this. If you weld it and it breaks again, you can only blame yourself then.
This is an example of the hole TwinTurbo was talking about. This is my Spohn torque arm that I had to shorten by 8". I used a piece of 1" thick solid bar to join the two halves, but just imagine the tubing adapter there instead. What I did was drilled a 1/2" hole straight thru so I had two places to weld. Depending on how deep the adapter goes in, you may have to use something smaller than 1/2".
Old Jul 25, 2010 | 10:43 AM
Tony89GTA's Avatar
Car: 89 GTA
I was kind of thinking the same thing with drilling a hole like that or either putting a nice solid pin through it, the back part of that tube adapter is hollow if that makes any difference.
From the product discription pretty sure this part of it was TIG welded but I'am not sure if it was ground down, I'am kind of guessing not from looking at it.
Old Jul 25, 2010 | 11:54 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
As others have stated, that weld is clearly faulty, Spohn should not balk at replacing that part. If they won't replace it, then I think that speaks volumes about their customer service and I would never do business with them again.
Old Jul 25, 2010 | 12:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Old Jul 26, 2010 | 03:25 PM
Tony89GTA's Avatar
Car: 89 GTA
Well just got some good news, just got off the phone with Spohn performance and they are going to send me out a new torque arm Nice to see a company standing behind their product!
Old Jul 26, 2010 | 04:18 PM
Car: '82 Z28
Good to hear
Old Jul 26, 2010 | 04:40 PM
Scorpner's Avatar
Engine: V6, V8
Old Jul 27, 2010 | 01:45 AM
Guest
Guest
Posts: n/a
I personally like Spohn products, but with that said, this should not happen. I would hope they are tesearching all products made that day buy that employee and are being retro active in warning clients about other possible failures. A breakage like that could easily kill someone.
Old Jul 27, 2010 | 07:42 AM
Twin_Turbo's Avatar
wanna sell the broken one?
Old Jul 27, 2010 | 09:00 AM
Tony89GTA's Avatar
Car: 89 GTA
Sorry I can't, they are paying for the shipping back of the broke one, they want to have a look at what went wrong with it. Basically 2 minutes after I sent in my pic's of it they called me back so it was a concern to them and something out of the norm.
Old Jul 27, 2010 | 01:21 PM
spade's Avatar
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
spohn FTW!! That was quick for them to call and send a replacement!
Old Aug 29, 2010 | 01:03 PM
hairysox33's Avatar
Looks like some incomplete penetration to me....
89newfun
Sep 16, 2015 09:28 AM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
luvofjah
Sep 10, 2015 10:41 AM
