Who has JAMEX spring part numbers?
Old 05-09-2001, 06:29 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I picked up a set of used JAMEX springs from Adam Cole. Backs went in sweet. When I pulled my stock front and went to install the Jamex springs, NO WAY! They would not even sit inside the spring centering humps in the lower a-arm or the upper coil tower!
The part number on the spring is Jamex2323 front.
I just cut a turn off my stock springs and got the perfect ride height. I couldn't have guessed any better. Two fingers between the tire and fendewell front and back.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old 05-09-2001, 05:30 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Rob, the correct part number is 2320. I just looked at mine.
John
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old 05-09-2001, 07:10 PM
RARE-ROC-Z's Avatar
hey john do you like your jamex's. there is a good set on ebay real cheap and i was wondering if i should buy them! thanks!
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 9 Bolt Borg-Warner 3.27gears
Bright Red Hardtop/ Grey Custom Interior
mods: AFPR, B&M megashifter-HD4ft cable, Underdrive Pulleys, Ported plenum, K&N's, Magnaflow muffler, Aluminum Driveshaft, Gutted Air Boxes w/ Ram Air, and more!!
soon to have new PAINT, and suspension work
DAILY DRIVER: 1991 S10 2.5L/5SPD -
Old 05-09-2001, 08:13 PM
Engine: 4.0L
Yes, I like the springs. They also do not rub. You can see before and after at my website to compare stock height and Jamex height.
86 Camaro Sport
My Camaro Project
1992 Trans Am
05-10-2023 07:19 PM
355sbcTPI
08-19-2015 04:38 PM
dcbsracing007
08-18-2015 07:24 AM
IrocZ'85
08-17-2015 06:24 PM
armybyrd
08-10-2015 09:23 PM
Quick Reply: Who has JAMEX spring part numbers?
