coil spring isolator
Old Jul 26, 2010 | 06:27 PM
skinny z's Avatar
Is there something in the aftermarket that's designed to replace the front coil spring isolator? Mine are a little on the distorted side and could use replacing seeing as the front end is dissasembled.
GM has the item listed as discountinued (not surprisingly).
Old Jul 26, 2010 | 06:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: coil spring isolator
Spohn used to have them. they are just thin rubber pads. Heater hose would accomplish the same thing.
here they are
http://www.spohn.net/shop/1982-1992-...Isolators.html
again, heater hose works, and its a lot cheaper. All they do is keep the springs from making noise with metal to metal contact
Old Jul 26, 2010 | 08:59 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
New or used, to save yourself time, energy and sanity, tape the isolator in place before attempting to replace the spring.
JamesC
Old Jul 26, 2010 | 10:13 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
just ordered two from rockauto....$6 each. I'm not being a wise#$! but I believe they're called insulators. Theres no shame in replacing anything with new stuff....especially when you have it apart and don't plan on having it apart for a long time. I'd replace a hose clamp if it started lookin old.
Old Jul 27, 2010 | 04:44 AM
skinny z's Avatar
I've been throught the tape thing before. Excellent advice.
As far isolator/insulator. I just referenced my GM manual. I stand corrected. It is insulator. (Thanks for the info)
Old Jul 28, 2010 | 10:19 PM
skinny z's Avatar
Interestingly enough, when looking for an "insulator" in the aftermarket, I find them listed as "isolators".
File Type: doc
Old Jul 29, 2010 | 10:26 AM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
tomato/tamato I guess........that's probably why the guys at pepboys and autozone had no clue what I was looking for.....they were cheaper at rockauto anyway
87v6Bird
Jul 1, 2018 04:12 PM
timonator
Sep 17, 2015 06:57 PM
sandman92084
Sep 12, 2015 10:27 PM
Jlanz55
Sep 6, 2015 03:05 PM
