**URGENT** Where can I buy Earls Braided Brake lines?
I want to know some where I can just call up and say, "I have an 87 IROC, with rear disc setup off an 89 Trans Am", and not have to give all kinds of weird measurements. Anyone know anywhere? I plan on ordering them tomorrow and I heard Jeg's was running kind of low, so I'd like to have some other places lined up to call. I'm going to need then fairly soon because I'm getting home from college Saturday, my IROC is my only car, and I'm in the midde of rebuilding the rear brakes. I don't want to put them back together without my new lines.
I also would rather get Earls because I heard Russil was kind of second rate.
Thanks in advance!
Thanks in advance!
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I bought mine from Jegs. Part # 036128A520 for 85-88 Camaro 4W Disc. The price was $89.99.
JamesC
JamesC
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
That P/N isn't going to work. He stated he's got the '89 rear brakes. Just specify '89 Trans Am, since unless you have 1LE's in the front the front brakes are the same 82-92.
I haven't checked which part number would fit your car. You can check it out at Jeg's site. One of them is the 1LE brakes though, so be careful. It would fit the rear brakes but probably not the fronts.
(edit)
28A190 is the 1LE brake kit... and that and the other kit listed are the only ones that show "4-wheel disc". I know the 1LE kit will have the correct rear brake hoses. The fronts might be made to work--they're kinda tight with the 1LE fronts... so maybe.
[This message has been edited by 99Hawk120 (edited May 16, 2001).]
(edit)
