C5 rims.....same offset as 4th gen f-bod?
Old May 15, 2001 | 07:15 AM
andrew350's Avatar
Would 2000 C5 rims have the correct spacing on a thirdgen if mounted on a fourth gen rear?
I guess my question is, do C5 and fourth gen f-bodies have the same offset?
Old May 16, 2001 | 07:07 AM
andrew350's Avatar
anyone?
Old May 17, 2001 | 03:13 AM
89GTA5spd's Avatar
I believe the fronts are the same offset (4th gen and C5), but the rear are different on the C5 and thus require spacers to fit on fourth gens. You can find out pretty easily on camaroz28.com or ls1.com.. just check the suspension board and search "C5 Wheels". Go onto skulte.com too and look there, I think it says what offset C5 rims need for thirdgens and might mention about fourthgens. I was going to go with some C5 rims on my GTA, but decided against it. Still have a good set of used C5 tires lying around because of it.. oh well.
[This message has been edited by 89GTA5spd (edited May 17, 2001).]
Warlocksirix
Sep 3, 2015 12:26 PM
cam-mike
Aug 24, 2015 07:23 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
