parking brake
Old May 18, 2001 | 04:19 PM
b92z28's Avatar
parking brake
i just put new brakes on all four corners on my 92 z that has rear disk. now my parking brake doesnt hold any more. i didnt take the cable or any thing loose. i took the top caliper bolt out and the caliper pivoted on the bottom out of the way so i could get the rotors off. before the parking brake was working but you had to pull it all the way up to make it hold. the car is an auto so it doesnt get used very often. can any one help me?
92 z28 170,000 miles 14.20 on goodyear eagles only mods k&n and muffler fell off!
87 trans am 12.20 on motor too many mods to list
Old May 18, 2001 | 08:30 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I have the same rear brake setup on my car,and my parking brake doesn't work either.
82Z 305 w/comp 270 magnum cam,Edelbrock Performer RPM,Holly 1850-4,serpentine belt drive.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
LittleFranks
Sep 17, 2015 12:22 PM
