95 Front Suspension into 83 Trans Am
Old May 19, 2001 | 05:34 AM
Gambit69's Avatar
Car: 1989 Pontiac Firebird Formula 350
I am wondering if the whole front suspension (rotors, calipers, struts, rack and pinion, control arms and sway bar) out of an 95 Camaro which will fit the 93 to 97 Camaros, Firebirds, and Trans AMs will fit into a 83 Trans am that i have and i am rebuilding or if they are two different suspension setups and that it wont work at all. Any help would be appreciated.
Old May 19, 2001 | 11:38 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Im pretty sure it wont fit. Besides the 4th gen front suspension isnt as good a design as the 3rd gen. We use struts up front, they use shocks. There are some other diffences too, but we have a better front end setup.
Old May 20, 2001 | 10:32 AM
Metalifann's Avatar
The fourth-gens use struts up front too. My fried has a 95 camaro and it has shocks in the back and struts in the front.
Old May 20, 2001 | 09:14 PM
formul8!!'s Avatar
Car: 2004 GTO
It is not a McPherson strut setup like the 3rd gen.
Anything can be done if you have the time,patience and of course the $$$$$.
Old May 20, 2001 | 11:22 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
Actually, as far as suspension geometry goes, the 4th gen SLA front suspension is a better design over ours. It offers equal-to-better performance with better ride characteristics. Unfortunately you cannot graft one onto our platform UNLESS spending mega-bucks utilizing a custom frame. Since the front track width would be wider you would have to widen the car by flaring the fenders & quarterpanels or using a wide-body kit (if you could find one anymore).
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
Exxon Limited
Aug 9, 2015 08:13 PM
