Fitting towing hitch ?
Old May 16, 2001 | 12:17 PM
82 T-TOP's Avatar
I am thinking of fitting a TOWBAR (I think Americans call it a towing hitch) to a T/A. Need pics or details as to what to attach to on the car. I know the ends would need to fit to the chassis members. But what else? I intend to try to keep it hidden by having a removable goose neck. Thanks guys.
Old May 20, 2001 | 10:49 AM
OLDYELLR's Avatar
Car: '85 IROC
I have a Reese shaddow mount hitch on my car http://www.reesehitch.com/79045_e74204_f_62.html although it does not look like the one shown, except for the actual hitch part. It is made of a 1.5" square steel tube with a pair of tabs welded to the back of it that run straight up to the bumper bolts and a pair of "dogleg" brackets welded under it, running forward and up to the rear subframe members, bolting on through existing holes. The hitch tongue slides into a hollow piece welded on the underside of the square tube.
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Torsen, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
Old May 21, 2001 | 07:43 AM
82 T-TOP's Avatar
Thanks John for your reply. Good to hear from you again. I will try your suggestion. Was not sure what to bolt to other than the chassis. The chassis and bumper bolts look the way to go. Thanks again.
TX-SleeperC5
Feb 24, 2016 01:34 PM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
Ranbo108
Sep 9, 2015 12:20 PM
TBRays98
Sep 6, 2015 05:05 PM
BOOT77
Sep 5, 2015 03:55 PM
