installing rear shock question
Old Aug 1, 2010 | 09:57 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
hey guys,
i have a set of rear bilstein shocks
when installed and the car is back to ride height.
how do you confirm you tighten the top bolt enough?
if the nut is flush with the sheet metal?
i was warned not to tighten to the point it might go past the threads of something.
can someone just tell me how its done when tightening the upper bolt?
Old Aug 1, 2010 | 10:11 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: installing rear shock question
I used my torque wrench and tightened it to the spec listed in the shop manual for my 92. I believe it did bottom it out on the shaft, but it was last winter when I replaced my shocks so I could be wrong.
Old Aug 1, 2010 | 10:16 PM
Bobby_80s's Avatar
Axle/Gears: no idea
ok thank you, anyone else wana chime in just to be sure?
Old Aug 1, 2010 | 11:39 PM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
I just tightened the until they were real snug. I've never had the nut on the top back off of any car I had.
Old Aug 8, 2010 | 08:14 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
yup you'll see it and you dont want to compress the bushing too much
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
