Tubed or Boxed SFC's which is better?
Old May 23, 2001 | 10:33 AM
BrianB's Avatar
Debating on getting tubed SFC's from BMR because I can get them in the color of my car, or getting boxed because they may be better? Your opinions are appreciated.
Founder of the Greater Cincinnati F-Body Association
1988 Yellow Trans Am GTA
Click here for photos
Old May 23, 2001 | 10:41 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm certainly no engineer, but as I understand it, a tube is stronger than a box. If you'd like pics of the Global West tubular version, let me know.
JamesC
Old May 23, 2001 | 12:51 PM
formul8!!'s Avatar
Car: 2004 GTO
The Hotchkis and Metco LCR's are a little over engineered and heavy for a fairly stock to mild street car.
BMR's are just fine. Go for the rubber/poly combo if you drive it daily. Will not be as harsh of a ride and still plant the tires hard on the pavement!!
Old May 23, 2001 | 03:23 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
"Which one do I choose? - While you can't go wrong with either design, use the following to determine your order: If strength is your number one priority, choose the boxed design. Boxed tubing is torsionally stronger than round tubing however you will lose approximately 3/4" of ground clearance when using this style. If your car is lowered and ground clearance is the prime concern, go with the tubular model. While round tubing is not as strong torsionally, there are other features to these subframe connectors that make them more rigid than most other tubular models available."
Straight from BMR's site. Depends on whether you need the clearance or the strength.
Old May 23, 2001 | 07:39 PM
91RedBigFinZ's Avatar
I didnt lose any ground clearance with my boxed Spohn connectors. Doug
Central Indiana Camaro Club member since Oct. 2000
1991 Z28 - 51,000 miles.
Dyno Results: 226.4 Max Hp; 310.4 Max Torque (ft-lbs)
All power options leather. 350 TPI:
K&N; Airfoil; Custom 'Ram-Air'; Slp Runners;Poweraid TB spacer;
Fastchip;
SLP Headers; Borla Catback 50% open; Dual factory Cats;
March underdrive pulleys;
Accel Extreme 9000 wires, Accel coil; Hypertech rotor & cap; NGK platinum plugs;
Manual fan switch;
TB coolant bypass; smog pump delete
Spohn subframe connectors (black powder coat);
Pirelli P7000 Z245/50/R16 all season tires;
Energy suspention motor mounts
S Cobra Radar Detector; Z28 SS Floormats;
Technalon IV car cover (now on my dad'a 2000 Berger SS).
75bike
Sep 20, 2015 09:37 PM
BLK87Z
Sep 18, 2015 11:29 PM
bubbaz28
Sep 18, 2015 02:09 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
