1LE Master Cylinder Answers
Old May 31, 2001 | 10:38 PM
Metalifann's Avatar
I checked the AC-Delco Durastop catalog today at work. This is what I found.
I was looking under camaro and I assume that the firebirds are exactly the same. The third gens came with two different master cylinders that the book listed.
One came on the 84-87 with rear disk and on the 88 with rear disk, but not the 1LE. This master cylinder had bigger bores than the other one. (25.4mm x 36.0mm) I assume that the smaller diameter is for the front brakes. The Durastop part# was 18M314
The other, "better" master cylinder was equipped all 89-92 third gens, 84-88 with rear drum, and 88 with the 1LE. This master cylinder had a smaller bore. (24.0mm x 31.75mm) The Durastop part# for this master cylinder was 18M313
If anyone needs any more info, ask and I'll see what I can dig up.
Old Jun 1, 2001 | 05:29 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
That stands to reason. Because when I removed the larger bore master cylinder from my car, and installed the smaller bore M/C. I noticed a dramatic improvement in brake effort/performance. I used a J50 M/C and booster from a 1986 Camaro.
Fireslash
Apr 11, 2016 06:43 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
usafirebird
Sep 29, 2015 11:58 PM
