Interesting find under the car.
Old Aug 13, 2010 | 07:14 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I was repairing some exhaust on my car and hadn't really been under this car much before. I got the rear end jacked up and was surprised to find that my panhard bar and both rear control arms have been boxed. Didn't expect to see it. I'm still going to be swapping to tubular ones, but these should be fine for now.
Anyone else find surprises modified under their cars?
Old Aug 14, 2010 | 11:21 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Interesting find under the car.
Yes, but very rarely in a good way
Old Aug 15, 2010 | 05:16 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
Exactly.
The most recent was on my truck. Previous owner did several things like run all of the differential vents to a hole in the floorboard... Oops, that hole is a water drain
Cut all the ends off of the starter connections, twisted the wires together and tightened the nut down on them.
Ignition switch started to go out, so he drilled a hole in the firewall to run a new ignition wire... Right next to the ignition wiring he was replacing (could've just used that one). Then drilled another hole in the dash for the push button in the permanent steel part of the dash instead of the plastic bezel right above it. Cost me $12 and a half hour of time to fix it properly and have a working ignition again.
A car will tell you volumes about people... LOL
Old Aug 15, 2010 | 05:33 PM
90HSR406's Avatar
Car: '90 RS, UH-60M
Engine: HSR'D 400
Transmission: TCI POS DONT BUY TCI!!!
Axle/Gears: Three2three
I still find weird stuff on my car that makes go what the heck were they... was I thinking? (its a one owner car.)
Old Aug 15, 2010 | 05:56 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
i found a pair of needle nose pliers sticking down at me the first time i crawled under my 89. free tools rule!
Old Aug 15, 2010 | 06:12 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Well, I did find more rust than I would have wanted, but its not too bad, and all repairable.
BlueIroc-Z
Jun 9, 2019 03:22 AM
TheJoeY88
Dec 31, 2016 07:30 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
overdriv
Aug 20, 2015 03:52 PM
