What do you guys think of Drag Shocks???
Old Jun 6, 2001 | 12:50 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
I don't want to go compareing two different cars but my friend just put some front Drag shocks on his 95 mustang and it made a fairly big improvement in launching and mostly with switching gears{ they would scratch a lot before}
anyone using them on the front on a third gen. ??
results ??
also how much will this kill my susp. as far as the handling ??
thanks for any info
Hecubus
Check out my new site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/Nos Wet Plate System currently ~200hp shot/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel,Air-fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt.
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
Old Jun 6, 2001 | 07:18 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Depends on the shocks. Most "drag" shocks are not recommended for street use. If the car is strictly race only, get a set of Koni SPA1 shocks. Next step down from them is some Lakewood 90/10 front struts. If you drive on the street, get some 70/30's.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 481.6
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Jun 7, 2001 | 08:05 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
HMMM
well I DO NOT want to screw my street susp. set up too much
what would you recomend that I do ??
Just leave it or go with a slightly different ratio?
I do want to get better traction when I go to the street races so this is not at the track but more on the street.....but dragging never the less
basically I'm trying to find out if it's worth it or not..
thanks for any help
Hecubus
Old Jun 7, 2001 | 08:22 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I raced my car for 2 years with factory shocks. I only installed the SPA1's after I broke my new engine so I haven't been able to test them yet.
If you intend to use the car on the street then just get some 70/30 Lakewood struts.
Old Jun 7, 2001 | 10:52 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
where would be the best place to buy the 70/30 Lakewood struts. ????
and much do you think I'm gonna shell out for em??
thanks Stephen
Hecubus
Old Jun 8, 2001 | 08:32 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Any speed shop or Jegs, Summit. They all carry them. Lakewood part number 40500. They are about $92 each. My SPA1 struts are $190 each.
customblackbird
Aug 15, 2021 10:16 PM
LT1Formula
Nov 16, 2015 01:13 PM
Street Lethal
Aug 14, 2015 08:25 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
