SSM ..... Complete Kit
Old Jun 7, 2001 | 02:11 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
Anyone installed the complete ssm kit w/ lift bars and cross-member? Opinions?
Carburated 5-speed
Vortec heads,1.6 roller rockers, .480 Crane cam,T-5,355 4-bolt, 3.73 posi,SSM Kit
Old Jun 7, 2001 | 10:34 PM
Baron's Avatar
EXACTLY what I was about to post...is it worth it with my mods to have a driveshaft loop and lift bars in addition to SFC's? Are the loop and bars even needed in a thirgen that much? What's the difference in performance, etc? I guess what I'm trying to ask is is it worth the $400 something for the whole kit, or should we stick with STB and SFC's? Thanks.
'89 RS LO3- 140,000 miles
14x3 K&N Open Element
Ram Heavy Duty clutch
Edelbrock TES (Jet-hot coated)
Catco cat
Edelbrock 3" Cat-back
Pioneer DEH-P77
Dual .50 caliber machine guns just under ground effects
Coming:
KYB shocks
Edelbrock Strut Tower Brace
South Side Machine subframe connectors
When your buddy reaches for a 10-pound sledge and says "I think we're gonna have to modify the floor pan, okay?" the answer is NO.
Old Jun 8, 2001 | 05:35 PM
Ben Franklin's Avatar
what is a ssm kit
I am a new guy
Old Jun 8, 2001 | 10:20 PM
Jza's Avatar
Jza
I had it but the lift bars and crossmember went into a '27 Ford. The SFCs and driveshaft loop went to my 89. That basically says what is really needed from that kit for a street car.
Old Jun 8, 2001 | 10:21 PM
Jza's Avatar
Jza
It's a well-made kit though... Probably worth the money for a drag car.
Old Jun 10, 2001 | 12:28 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
http://www.southsidemachine.com/
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Terrell351
Jun 13, 2021 01:13 PM
toronto formula
Nov 10, 2015 06:17 AM
C409
Sep 23, 2015 04:30 PM
Mickeyruder
Sep 2, 2015 02:45 PM
KO1
Aug 31, 2015 06:31 PM
