How much will a rear sway bar from a 93 Z help me?...
Old Jun 13, 2001 | 07:13 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Cause I want my car to have more oversteer. As I know of the 93Z rear sway bar is 2mm bigger than my sway bar. Will this help much with oversteer? thanks
Chris
91 RS 305 TBI
Eternal Rev
Old Jun 14, 2001 | 09:38 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
et some nice iroc sway bars and wonderbar.. this will help the suspension and improve stearing
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler, white guage faces, megashifter..
next month: spohn LCA's and panhard rod, BMR relocation brackets, 323 gear, lt1 cam , 350 heads
Old Jun 14, 2001 | 12:18 PM
SteveSpohn's Avatar
The largest 4thgen rear sway bar is the 1LE which is 21mm. The thirdgen rear bars are much larger, with the 1LE being the largest at 24mm, most Z28's came with a 23mm.
Steve
Spohn Performance: F-Body Chassis/Suspension Specialists
Old Jun 14, 2001 | 04:32 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
All late 80-s and up IROC's, & TA's, that had RPO code FE2 have 36mm front/24mm rear swaybars. WS6, B4C, & 1LE's had the same bars too.
Old Jun 14, 2001 | 07:38 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
A thicker bar on the back should produce more overstear. Counter example is that on a wet track you loosen up the roll bars so that you have more grip.
However, this is trial and error stuff so it's difficult to predict how much overstear you'd get with a 2mm difference on your particular car.
Air pressures make a difference too.
Also, a way to produce overstear is to get more grip at the front so a thinner bar at the front should help.
You need to change one thing at a time and then see what it does.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
