rear wheel spacers
Old Jun 12, 2001 | 07:34 AM
88transam5.0's Avatar
rear wheel spacers
I recent purchased some ROH Reflex wheels 17's and do I need to add spacers on the wheels.
Old Jun 12, 2001 | 12:09 PM
Camaro_hunter_d's Avatar
did you order htem with 5 1/2" backspacing?.If so the no.
Old Jun 13, 2001 | 01:45 PM
<font face="Verdana, Arial" size="2">Originally posted by Camaro_hunter_d:
did you order htem with 5 1/2" backspacing?.If so the no.</font>
Hi camaro hunter, I didn't understand what you meant by htem with 5 1/2 spacer. thanks
Old Jun 20, 2001 | 12:29 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Backspacing is the distance from the surface of where the rim meets the rotor (or drum) to the lip of the rim on the back (the side you can't see when the wheel is mounted. Look here: http://www.skulte.com/offset.gif
If the backspacing of your rims isn't 5.25 as mentioned you need to get spacers. to increase it to that amount.
Old Jun 20, 2001 | 01:14 PM
look at my other posting on wheel spacers, there a company AIM that has them for dirt cheap. try 2 inch spacers for 59 bucks....and they can make any sized spacer you want just call them.
1992rs/ss
16
Jan 28, 2016 09:58 PM
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
