Non adjust panhard bar & Lca Not lowering ?
Old Aug 20, 2010 | 07:51 AM
Rons91Bird's Avatar
Car: 1990 GTA, 75' Formula 400
Engine: 305 TPI, BB400
Transmission: Automatics in Both.
Axle/Gears: 2.73 in the GTA, soon to be 3.42
I'm playing around with the suspension on my newly aquired 90 GTA. New Sway bar bushings end links, wonder bar, subframe connectors.
I have no intentions of lowering the car ( it's fun enough getting out of it and my 01 ) Height is fine to me.
Would the non adjustable panhard and non adjustable LCA's be of any benefit? ( poly/poly)
Thanks ..
Old Aug 20, 2010 | 08:06 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Non adjust panhard bar & Lca Not lowering ?
The standard npn-adjutable rear LCA"s & panhard bar would work for you. I have the non-adjustable Spohn parts as a upgrade from the cheap factory style.
My personal opinion is leave the adjuable stuff to the guys who like to turn wenches all the time.
Old Aug 20, 2010 | 08:20 AM
Rons91Bird's Avatar
Do you have any issues with binding? I have heard some say they have issues with binding due to the poly/poly bushings. I'm not running major horsies ( 305 TPI ) But just want a good solid suspension.
Old Aug 20, 2010 | 08:27 AM
DJP87Z28's Avatar
No......
Old Aug 20, 2010 | 08:49 AM
Rons91Bird's Avatar
Thanks !!
Old Aug 20, 2010 | 09:16 AM
Stephen's Avatar
Car: 87 GTA
Zero binding issues from my UMI pieces.
On my GTA, despite my stock PHB having poly bushings & the car still riding at stock height (no lowering or worn out springs), my rear axle was offset to the drivers side by almost a full inch. If I had wanted to stay with stock 245-sized tires, that woulda worked fine. But to fit my 315s, I needed the adjustable PHB to get the axle centered correctly to get both sides to fit.
Old Aug 20, 2010 | 12:53 PM
Rons91Bird's Avatar
I was looking at the UMI stuff.
How would your rear axle get out of alignment almost an inch? Hard drivin?
Old Aug 20, 2010 | 01:07 PM
Stephen's Avatar
Car: 87 GTA
No clue. My bushings look good. My mounts look good. My bar looks good.
So I dunno what was causing it. But my UMI piece sure fixed it!
Old Aug 20, 2010 | 01:11 PM
Rons91Bird's Avatar
Thanks stephen for you input, appreciated.
Old Aug 20, 2010 | 01:21 PM
Stephen's Avatar
Car: 87 GTA
Not a problem. I used a string having from each fender lip (with a washer tied on the end) to see the difference & adjust the UMI piece square.
If your staying with 245s, you probably won't even notice the difference enough to bother you. I didn't until I put 285s on & was ready to do the 315s.
Old Aug 20, 2010 | 01:33 PM
Rons91Bird's Avatar
If i stay with the stock 245's, i can go with the non adjustables, Yes? With no problems.?
Old Aug 20, 2010 | 01:43 PM
Stephen's Avatar
Car: 87 GTA
Shouldn't be a problem. There is plenty of clearance for 245s.
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Strick1
Sep 4, 2015 07:11 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
Night rider327
Sep 2, 2015 04:18 AM
