question about front sway bar mid link bushings(to frame)
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
I've changed a bunch of these in my day but I'm stuck on this one. I've tried changing my mid links with poly but the energy suspension brackets don't line up with the bolt holes in the frame and the their bushings don't fit in the stock brackets. So... I ordered MOOG bushings that supposedly are molded to the stock brackets but they're like a half inch taller than the stock brackets. What am I missing? Is there another bracket I can buy to fit with the MOOG bushings?
Car: 87' IROC
Re: question about front sway bar mid link bushings(to frame)
I'm not sure what your problem is. Maybe try Top Down Solutions. They'll sell you a complete kit (bushing, shell, bolts) that will fit.
Car: 1991 RS
Engine: 383 stroker
Yeah...thanks....thats what I plan on doing. I keep forgetting about TDS even tho I've purchased a few things there.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Are you measuring the sway bar and ordering/getting the right size bushing? You need to scrape all the gunk off the bar, and measure it's diameter - there were 30mm, 32mm, 34mm, and 36mm bars.
Car: 1983 Crossfire Recaro T/A
Engine: 5.0L Crossfire
Transmission: Upgraded 700R4
Axle/Gears: 3:23
I just upgraded to a 36mm hallow bar. I couldn't find an energy suspension bushing, so I went with Moog 1-7/16" size (will have to look up part number if you need it).
My original mount brackets would not bolt in. Compared them to the ones that came with the 36mm bar I bought used, and there was a difference in the size of the mount brackets
The Moog size I went with may be a tad too large, but it did mount. Not sure of the effect on the cornering - seems fine.
Can confirm that 83 T/A will fit a 36mm hallow bar, Moog 1-7/16" bushing, stock 36mm bushing mount bracket will mount while using a Spohn wonder bar and Energy Suspension link set.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
http://www.top-downsolutions.com/pro...products_id=43
http://www.spohn.net/shop/1982-1992-...-Bushings.html
JamesC
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
