Will a bigger rear sway bar help with traction?...
Old Jun 26, 2001 | 07:19 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Just wondering. Cause I'm going to put a 4th gen rear sway bar on my car (free). And am going to the tracks on wednesday. So I was just wondering if I should just put it on now. Or no need and just wait till later. Thanks.
Chris
91 RS 305 TBI
Eternal Rev
Old Jun 26, 2001 | 10:01 PM
82camaro's Avatar
Car: 82 camaro SC
Auto cross or drag? How much bigger is it?
Auto cross, your car will tend to be 'loose' when turning with the mis-matched big rear bar. On the strip, a rear bar is helpful, but going to a bigger bar doesn't usually make your car faster.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
