Air bags on a thirdgen?
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Has anyone ever put air bag suspension on a thirdgen? Does anyone make a kit, or parts to do it? I would like to drop my car really low, but raise it up for the highway.
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
1983 Firebird
TH700R4 Auto
Small Block 400
i run them on my drag car. i use around 25 pounds in the right and 5 or 10 in the left. air lift makes the ones i have.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I think he's talking about a total air bag system that replaces the factory springs.
No. There is no kits available for such a thing.
The air bags that ede and I use fit inside the rear springs. They're more of an overload spring. You pump them up to change the ride height but you still need regular coil springs.
I put 15 psi in the passenger side and 5 psi in the drivers side. This helps keep the passenger tire from coming off the ground. When properly tuned you can even get an open diff to hook up like a posi.
As for using them to drop the car's frame onto the ground, they won't work. You'll need to design and build your own system to do that. The f-body chassis design isn't designed properly to be able to do it anyway. The floor is too low or the rear axle sits up too high depending on how you look at it..
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
Car: 1988 GTA
Engine: 5.0 TPI
What want to be able to do is have my car sit as low as possible with 17 or 18 inch wheels, bt be able to raise it up to stock height if possible so i can actually drive it. I found a set of strut/airbag combinations which are sold by AIM. The downside is they are $499 a pair. The yalso make shock/airbag combinations but they are just as expensive. I was wondering what would happen if I replaced the front springs with Firestone bellow style airbags and used the air shocks like you and ede run in the back. I dont know alot about suspension, so would that work at all for what I want? BTW, i want stiff suspension to stick to the ground good.
1983 Firebird
TH700R4 Auto
Small Block 400
1983 Firebird
TH700R4 Auto
Small Block 400
Car: 87 IROC L98
We don't use air shocks in the rear. I have drag shocks. We use air bags inside the rear springs from Airlift (Slamair). They're basically an overload air bag. If you throw too much stuff in the back of the car you just pump up the bags so it sits level again. Racers use them to help preload the suspension. It takes more force to compress an air bag than it does a coil spring so the tires will plant harder.
What you want to do isn't going to be cheap no mater how you plan it. Third gen suspension just isn't designed to be changed like that. There's too much steering and driveline geometry that will change.
I emailed a big airbag kit company and they didn't even get back to me.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
