Sway Bar Bushings
Old Jun 25, 2001 | 10:07 PM
BORLAZ06's Avatar
Sway Bar Bushings
Where can I get 36mm and 24mm sway bar poly bushings? Thanx
[This message has been edited by BORLAZ06 (edited June 25, 2001).]
Old Jun 25, 2001 | 10:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Energy Suspension or PST have the 24mm rear one. As far as I know only Guldstrand has a 36mm front one. I just used the stock high-durometer rubber ones for the front.
Old Jul 6, 2001 | 05:54 PM
Eightyninef's Avatar
did the stock 36mm bushings fit on the 36mm bar. I had trouble getting them on there.
Old Jul 6, 2001 | 06:39 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's a tight fit once they're compressed by the bracket.
Old Jul 7, 2001 | 06:19 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
I recently upgraded to the IROC swaybars, and I am using the Guldstrand bushings. I am very happy with them. My car feels MUCH better in the corners now. Just make sure to use lots of the poly grease supplied, or you may get a lot of squeaks.
Ed1LE
Sep 30, 2018 09:14 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
