Making E-Brake work
Old Jul 10, 2001 | 12:22 PM
Ben Franklin's Avatar
Making E-Brake work
I have a 91 Z28 with the G92, so i have disc brakes. Sometimes my e-brake doesnt work or when you pull it there is no tension. Is there a way to fix this. I heard you can adjust this but have only heard how to do it for drum brake cars. Thanks
Old Jul 12, 2001 | 07:39 AM
Mark W. Winning's Avatar
My 92 was doing the same thing. When I was swapping in the T-56, I noticed that the area on the e-brake lever, where the cable attaches was covered with grease and junk was stuck in it. When you pulled up the brake, the cable would slide on the lever, instead of pulling the rear brakes. I cleaned it all off with brake cleaner, put a spot grease on it and all is well again.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old Jul 12, 2001 | 08:59 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Check the slack in the system. Raise the car and take out the driveshaft. At the tol of the tunnel, you will see the left and right brake cables attching to a single cable. That single cable as a screw on it. Tighten the cable and you should be all set. Make sure the cables are where they are supposed to be (there are a couple of hooks where the cable lays into) That should cure your lack of an e-brake problem.
  • 89 Formula 305 WS6
    SFC's, LCA's, Air Foil
    Spohn Panhard Bar
    Flowmaster Cat Back, Tranny Cooler
    A/F Ratio Meter (not a mod but it sure spurs interest)
    Trans Temp Gauge
    Most "Free" Mods
    3:73, Zexel Torsion Posi
  • 90 Eagle Talon 2.0
    (Winter Beater)
    Mods? Um, no
    Its for sale!!
    Email me if you need a decent back up car
Old Jul 12, 2001 | 11:03 AM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
No the bracket does not have a screw in it. I believe the design was changed in '90. Trust me though, in my '91 there is no adjusting screw. The parking brake is said to be "self-adjusting". I had the same problem as Mark. The cable slid off of the track at the arm. I had to take the console out to fix it but it works pefect now.
Old Jul 12, 2001 | 11:58 AM
Thanks guys, now i just have to find someone that will let me use a lift! How hard is it to drop the drive shaft? If only my dad made the back garage 2 feet taller i would have a lift.
the lever is that inside the car or on the bottom of the out side?
[This message has been edited by Ben Franklin (edited July 12, 2001).]
Old Jul 14, 2001 | 05:41 PM
Jason M 91Z's Avatar
Disc E-brakes suck. I can yank up on my e-brake while I'm stopped and in gear, and it'll roll right through. I have brand new calipers and pads in the back.
-Jason M. 1991 Camaro Z28
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
Poncho92
Aug 7, 2015 08:15 PM
