master cylinder, or???........
I have had this problem for a few months now, and the past 2 weeks it has gotten worse. I knew I needed brakes in the rear and the front were pretty low too. I got the rears done (dont get involved with drums) and replaced the rotors and pads up front. My problem still exists, the pedal goes down like 80% when i press on the brakes. I noticed in the reservior that there is a lil sludge in the bottom. Could the prop. valve not be gettin fluid from a clog? Or it the MC just on its way out. Im new to workin on brakes and i dont wanna screw up something that may have to save me one day (I live in Jersey, so I need them working 110%) Any help will be appreciated.
Car: 87 Formula Firebird/ 84 Trans Am
Engine: 305 / 305 H.O.
Transmission: 700 argh 4 / same
The power assistor may be knockin on heaven's door. Check to see if you can create a vaccume? with car off. If the breaks were done right they would pull the fluid in or find a hole in the line to get something to fill the vaccume in the line.
my .02 though
You put Mt. Dew in the gas tank!?!
Wow, look at it go!
1984 L69 305HO WS6 Firebird Trans Am
Current Mods[*] 2 1/2" Flowmaster cat back[*] gutted cat[*] 160 thermostat[*] all around polyurethane bushing kit from Energy Suspension[*] 3.73 Disk rear
Mods to come![*] 350 .30" SB [*] Comp Cam[*] Edelbrock RPM Proformer Package [*] 3.73 Posi Disk rear[*] Edelbrock TES headders - Yeah I like em![*] 150 lb shot Edelbrock Nitrous System[*] Edelbrock Aluminnum Signeture Series Valve covers.[*] 140 amp GM High Proformance Altnator
my .02 though
Wow, look at it go!
