car not tracking straight.
Old Sep 8, 2010 | 05:17 PM
quick87formula's Avatar
Car: 87 formula
Transmission: 700
Axle/Gears: 12 bolt strange 3.73
on my 87 formula. i have all the suspension done with all sphon adj. stuff. torque arm
pan hard bar
lower control arms.
when i do my burnout the car just wont go straight. when she brakes loose she swings side to side.
any ideas what part of the suspension should i start with.
Old Sep 8, 2010 | 05:24 PM
Matt S iroc's Avatar
Re: car not tracking straight.
what rearend work have you done?if its limited slip possie i dont think youll get it to burn out straight cause one tire will always spin alittle faster.if you put a locker on it that will make both sides the spin the same.
Old Sep 8, 2010 | 08:11 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
make sure the lcas are adjusted the same length. actually you might want to measure wheel base on both sides of the car and make sure it equal.
Old Sep 10, 2010 | 04:06 PM
Car: 87 formula
Transmission: 700
Originally Posted by Matt S iroc
what rearend work have you done.
i have a 12bolt strange rear.
Old Sep 10, 2010 | 04:08 PM
Car: 87 formula
Transmission: 700
you know i didn't measure the entire wheel base of the car. i only measured the tire to the quarter edge. i will have to try that.
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
