Pop sound from front end!!!! What could it be?
Old Jul 22, 2001 | 02:35 PM
HT 1985 IROC-Z's Avatar
I have an '85 Iroc and here lately whenever I am turning the wheels and going over bumps in the road, there is this horrible poping noise from the frontend. Just a single pop, not a rattle or anything. I have been thinking maybe balljoints? I checked them for wear like the manual said, but couldn't really tell. I have replaced my sway bar bushings so I know it isn't there. All the tir rods feel tight and not wobbly. Could the problem even be coming from the steering column? I need help bad, because I think it is getting worse and it is quite annoying to hear it, sounds like something is gonna break or is broken.
1985 Iroc-Z, 5.0 liter H.O. Black cloth interior, Hard Top!! [ no LEAKING T-tops...YES!!! ]Upgrades: Edelbrock Performer Rpm Intake, Holley 650cfm Zinc-plated carb, Flowmaster exhaust,Accel 8.5 spiral core wires, 700-R4 w/shift kit [ I think it is broken...NO!!!! ], 3.08 rear[ can you say slow!! ]
Soon to have:
A paint job!!! White w/ black sripes, Headers and y-pipe and 3" I-pipe, World-Class 5-speed swap, 3.42 gears, Lots More!!!!! If the funds are available!!
Old Jul 22, 2001 | 04:22 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Ball joints, tie rod ends or wheel bearings. Have it checked out properly before something falls off.
Old Jul 23, 2001 | 08:34 PM
robbob's Avatar
Check your strut tower bearings,that's what was wrong with mine.
Old Jul 24, 2001 | 10:47 PM
CrazyRob75's Avatar
check around the steering box for cracks on the frame. That will cause a pop and sloppy steering depoending on the severity of the crack(s)
85 Berlinetta Iroc exterior NOW 454 powered, 4.10 gears, 275/60/15 Hoosier Quicktimes and a PILE of other goodies..........YES, it's street driven!
check it out at http://www.bsronline.net/members/rob/rob_specs.html
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
bellez77
Sep 5, 2015 08:39 PM
db057
Aug 22, 2015 08:17 PM
