Steering Column Loose Connection
Car: '91-Z28/'03 Honda 919
Axle/Gears: '99 Zexel 3.42
Hey I just installed ebay steering column which is suppose to be a GM original piece. i am having fitment issues where it bolts to the one that comes out of the firewall. I orginally torqued the bolt to the factory specification and there was a bunch of play side to side. So I torqued it down more and still nothing. The steering wheel has about a half inch of play due to this connection. Any ideas on how to resolve this issue. Thanks
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Re: Steering Column Loose Connection
The end of your steering column (where the bolt goes through) is necked down isn't it? Going from memory, I think they are.
The "replacement" part may be designed for a column with a non-tapered steering shaft. Not sure you got the correct part.
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
where did u get the part on ebay? wat store? got a link? How much?
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
