Anyone know the length of the swaybar endlink sleeves?
Old Aug 2, 2001 | 09:49 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
I wanna order new swaybar endlinks for my 92 RS anyone know the length of the sleeves on the front and back,or better yet the part# for the ES links...
92RS
Old Aug 2, 2001 | 10:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
9-8117G for the fronts, the rears come in a kit with swaybar bushings, P/N varies with swaybar size, my 24mm set was 3-5147G.
Old Aug 2, 2001 | 11:00 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
thanks....anyone ever try using the ES 35mm greasable bushings for the front, with a 36mm bar?if so what part # did you get? 9-5168 or 9-5173
92RS
Old Aug 3, 2001 | 08:40 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
They're 2 5/8" inch.. remember to change the "G" on the end of that part # for the color you want... although most stores only stock black- the others might be backordered.
G = graphite (black)
B = blue
R = red
Y = yellow
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Sep 22, 2003 | 10:36 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
Can I use ENS-9-8117G for the front and rear are they the same size endlinks?
Old Sep 23, 2003 | 03:21 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep, they are- according to the catalogs, anyway. If you lower your suspension, you can tune the end-links later by shaving down the sleeve length. The idea is to have the ends of the sway bar be parallel to their mounting brackets when the weight of the car is on the wheels and the car is level.
But for further proof, just slide under the back of your car and measure the stock sleeve length...
Old Sep 23, 2003 | 05:30 PM
Diggler86's Avatar
Car: 86 TA
Oh, Im planning on using the Eibach Pro kit springs, do you think I will have to modify these?
1" drop only. I didnt realize the drop would effect the endlinks but i see what youre saying.
Thanks.
wigmobile
Feb 26, 2025 02:56 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
Scorched1984
Sep 15, 2015 03:42 PM
