coil-over tubes
Old Sep 18, 2010 | 05:32 PM
tirerub's Avatar
coil-over tubes
Im trying to install coilover kit from racecraft and i dont know how to get the tube over the top flange on the lakewood struts do i grind the flange down. Thanks
Old Sep 18, 2010 | 07:26 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Re: coil-over tubes
Yes, you'll have to grind down the "flange" as you call it on the top of the strut.
I don't know if Racecraft makes their kit in house or if they use Afco sleeves. But if they use Afco sleeves (I'm pretty sure they do, but I'm not 100% positive) I think you'll need to turn down the inner diameter of the sleeves, because they are still a fraction of an inch too small to fit over the lakewoods.
I tried doing this (With Afco's and Lakewoods) and that's what my measurements with a micrometer told me. It was only a few thousandths of an inch, but just enough that they wouldn't fit if I remember correctly. But I don't have the exact measurements anymore
Old Sep 18, 2010 | 08:12 PM
tirerub's Avatar
Re: coil-over tubes
Thanks for your help, the instructions for the sleeves were from strange eng. My only concern is this safe to grind down. Is the strut going to fall apart is going to leak.
Old Sep 18, 2010 | 08:18 PM
Re: coil-over tubes
Well, don't grind too far obviously
And be sure to keep the strut rod well protected, scratches in that will really shorten their life.
But yes, it's safe to grind the "lip" down
gixxer92
May 18, 2017 11:20 AM
no green
Jan 9, 2016 09:22 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
FormulasOnly
Oct 2, 2015 05:52 PM
zman1969
Oct 1, 2015 11:09 AM
