Tubeular K-member ??'s
Old Aug 4, 2001 | 12:55 PM
R.O.B.'s Avatar
Is using the tube k-member an upgrade for a street car? I know it saves a lot of weight, but is its purpose only for the drag strip? It looks so small and punny, is why I ask. Also, what is the diff between "mild steel" and "chromoly"?
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
48psi regulator, (Nickel method)
Old Aug 4, 2001 | 02:13 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Chromoly is lighter and stronger than mild steel.
Old Aug 4, 2001 | 03:07 PM
R.O.B.'s Avatar
Thanks Stephen, but what about the k-member itself. Is it ok for daily driving, street racing, etc..
Old Aug 4, 2001 | 04:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Probably. You'll have to ask the manufacturer about their opinion about using it on the street. If they guarentee that it won't bend or break during street use then it should be ok. Don't forget, factory components are designed to last for the life of the car and will take a fair amount of abuse. Aftermarket and race parts are usually not in the same catagory.
Old Aug 4, 2001 | 09:21 PM
a383z's Avatar
I have the tubular K frame on my car for about two months now and its not bent or doesnt look bent and I have had no problems with it I went with mild steel cause chrome moly breaks if somehing goes wrong and if your K frame breaks your more or less screwed so atleast with the mild steel if I happen to bend it somehow I would be able hopefully drive it home.
1992 383 Z-28 w/SuperRam intake and ACCEL DFI, PA Racing K frame,SS hood,SS rims
Old Aug 5, 2001 | 01:39 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
I've heard that Chromoly is more britlle than the mild steel. I'd rather have something like that bend than crack
Scott
Old Aug 5, 2001 | 04:06 AM
german-motorsport's Avatar
383 did you use the rack option too?
i wonder about the 13.50on the 1/4??
what kind of tires did you use the 383 just do better?! the topic was up here before: https://www.thirdgen.org/messgboard/...ML/002179.html
www.camaro-firebird.de
Old Aug 5, 2001 | 11:47 AM
86 IROC's Avatar
I had heard of these for Mustangs, but not for our cars. Who makes them? Where can I get info about them? Anybody got a link? Thanks.
"I know why you want to hate me, cause hate is all the world can seem to see lately....." L.B.
Old Aug 5, 2001 | 01:29 PM
a383z's Avatar
I didn't use the rack option. I have the A-arms too just havent put them on yet I am waiting to buy the coilovers. I was waiting to find a cheaper price but I think I finally found somone cheaper. As far as tires I run a 255/40R17 on the front and a 285/40R17 on the back, the back rubs every now and then so I rolled the lip and its mostly ok now.
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
Mdenz3
Sep 17, 2015 08:36 AM
tricky1
Aug 23, 2015 01:17 PM
overdriv
Aug 20, 2015 03:52 PM
NBrehm
Aug 5, 2015 07:57 PM
