I busted a bolt on me tires!
Old Aug 8, 2001 | 11:59 AM
un4givin89's Avatar
Alright I was changing my tires the other day and when I was trying to remove on of the lug nuts it busted right off with almost all of the thread. I got the tire back on and all, but I'm wondering if not having that one lug and it being broken is gonna like become a serious HAZARD to my safety??
If it is something I should worry about any ideas on how much to replace that lil bugger?
Old Aug 8, 2001 | 12:44 PM
92fire-audio's Avatar
Depending on which tire the bolt broke off on, it may not be that hard to change. If its on the front, just change the rotor for a new one, you can get them for $13 at autozone (unless you have the 1le brakes) and if its on the rear rotor you can hammer it out and put a new bolt back in. On a FWD car it's SUPER easy to change but not so easy on a RWD car...
Old Aug 8, 2001 | 01:52 PM
un4givin89's Avatar
Its the front bolt on the Passanger side of the car. How hard?
Old Aug 8, 2001 | 02:09 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If your rotor isn't worn out you can just change the stud. Go buy a new stud. Pull off the rotor. Hammer out the broken stud. Hammer in the new stud and reinstall the rotor. If the rotor is close to worn out then just replace the rotor. It will come with new studs.
If you need instructions on how to remove a rotor either buy a Chilton or Haynes manual or have someone at a shop do it for you.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Aug 8, 2001 | 02:13 PM
un4givin89's Avatar
I got a manual, i just changed my brakes, I'll go jack it up this weekend and take a close look at the rotor, doesn't seem to be wore out that much.
Frozer!!!
Jan 19, 2024 04:55 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
BlackMagic1984
Wheels and Tires
Aug 24, 2015 06:35 AM
Dialed_In
Aug 20, 2015 01:45 PM
