factory line lock
Old Aug 9, 2001 | 06:17 PM
AUTOGON350's Avatar
Car: 93 S10 blazer
factory line lock
any one know why my factory rear drum brakes dont work? THey appear to be in good condition but they really dont do any stopping untill I stand on the pedal. Even then stopping help is minimal. it was kinda cool at first but after almost hitting cars when parking on gravel I thought I should look into this.
1990 TA 350 TPI
SPORTSMAN II HEADS
COMP CAMS 224-230@.50
52MM THROTTLE BODY
24LB INJECTORS
Old Aug 9, 2001 | 06:47 PM
ede's Avatar
ede
could be internal leak in the master cylinder, colasped rubber lines, leaking wheel cylinder, not adjusted correctly
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Aug 9, 2001 | 07:00 PM
AUTOGON350's Avatar
Car: 93 S10 blazer
I did have a brake line that was hit by the motor when I was taking it out. It didnt look like it was smashed but I guess I will replace it just in case.
1990 TA 350 TPI
SPORTSMAN II HEADS
52MM THROTTLE BODY
24LB INJECTORS
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
mx127
Aug 10, 2015 08:13 AM
