manual steering
Old Aug 9, 2001 | 06:24 PM
AUTOGON350's Avatar
Car: 93 S10 blazer
manual steering
just wondering has anyone switched to a manual steering gearbox? if so how is it?
1990 TA 350 TPI
SPORTSMAN II HEADS
COMP CAMS 224-230@.50
52MM THROTTLE BODY
24LB INJECTORS
[This message has been edited by AUTOGON350 (edited August 09, 2001).]
Old Aug 9, 2001 | 06:46 PM
ede's Avatar
ede
i did, no big problems, but my car goes straight except for a turn off to the left a little more than 1/8" mile away from where i started
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Aug 9, 2001 | 07:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
For street use it's not really recommended especially if you use large 16" tires on the front.
Fot trying to reduce weight in a drag car it's very easy to do. Look for an S-10/S-15 with a 4 cylinder in it. It should have a manual steering box. It's a direct swap into an f-body. You don't have to, but you should reuse the f-body pitman arm. It has a slightly different bend than the S-10's.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Aug 10, 2001 | 02:12 AM
german-motorsport's Avatar
Another option is a rack unit but you will have to go with the pa kit or create your own !
The S10 conversion is the cheapest and its easy to put on!
The real thing would be a power unit like on 88 ´Fieros (elektric) and make that speed senitive....america got that on the caddy´s i wonder when the industry is waking up????
This post will help to get more info:https://www.thirdgen.org/messgboard/Forum15/HTML/002179.html
www.camaro-firebird.de
Old Aug 10, 2001 | 08:18 AM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
I have pictures of a manual box on my website and some helpful tips.
John
82 Firebird,408,Dart Iron Eagle 215's,Cam 229/239, .498/.520,TH350 Tranny, 750 Speed Demon carb, Hooker Headers(I.E. POS) Manual steering, Bfg DR's.
Check out my birds new home.
Best et 8.21 @84mph in the 1/8th
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
