Weird Noises
Old Aug 9, 2001 | 09:03 AM
Purple 92 SS's Avatar
Car: 1992 Z/28, 2000 SS, 1968 RS/SS
Engine: 355 Built a bit / LS1
Transmission: T-5 / A4
Axle/Gears: 4.10 / 2/73's
Weird Noises
Yet another issue
heres info :
406/t5 (from 87 irocz) factory driveshaft and rearend. Lowered with Jamex Springs about a year ago almost.
heres problem, when accellerating at any speed either mildly or getting into it, i have a grinding, a lot of back "shaking" coming in from the shifter and odd noises. was wondering what may be causing it. Everythign else on suspension is factory, and i just replaced my rear spring insulators the other week with brand new ones from GM. That seemed to help for a bout a day then the grinding/ noises/ shaking came back. any ideas??
thanks in advance.
-steve
92 RS/SS FrankenCamaro
More mods to list than time to do it in
www.groundzerocustoms.org
Old Aug 9, 2001 | 06:55 PM
nicmike85's Avatar
Check the trans fluid level.
Old Aug 10, 2001 | 08:26 AM
<font face="Verdana, Arial" size="2">Originally posted by nicmike85:
Check the trans fluid level.</font>
tranny fluid is fine, but that wouldnt cause the rear end noise im getting would it?
I mean most of my noise is coming from behind me whenim driving, andi dont think that its something transmisison related.
-steve
Old Aug 10, 2001 | 03:11 PM
StockBastard's Avatar
check your rear wheel bearings, then check your rear gears. Mine did something like that several years ago, and when we removed the dif cover the spider gears fell apart and out onto the ground. It was amazing that they still giving movement at all!
Old Aug 13, 2001 | 08:30 AM
<font face="Verdana, Arial" size="2">Originally posted by StockBastard:
check your rear wheel bearings, then check your rear gears. Mine did something like that several years ago, and when we removed the dif cover the spider gears fell apart and out onto the ground. It was amazing that they still giving movement at all!</font>
ok will do... to me, it kinda feels like the car is riding toooo low if you know what i mean.
-steve
db057
Jan 10, 2020 08:55 PM
gta892000
Aug 11, 2019 11:16 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
