no brakes!
Old Aug 15, 2001 | 01:30 PM
nothingssafe's Avatar
Car: 86 TA
no brakes!
ok well i do not have any brakes. they go almost all the way to the floor when i hit them. then the brake light comes on. only the rear brakes are engaing, like i was pulling up the parking brake. i just replaced my master cylinder and booster. also my pads and shoes are fine. any ideas?
1988 Camaro
2.8 with T5
K&N
Soon to be CAI or Ram Air...
http://www.nothingssafe.com
Old Aug 15, 2001 | 06:32 PM
Going Slow Sucks's Avatar
There might be air that's trapped in the system.Try a gravity blead, and then blead them as normal.
88 Camaro IROC-Z
350TPI
K&N filter , High flow exgaust (no cat's), automatic tran's shift kit
Old Aug 15, 2001 | 06:58 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
<font face="Verdana, Arial" size="2">Originally posted by Going Slow Sucks:
</font>
GSS likely meant a gravity flush, then bleed the brakes. The brake light is coming on because the system is sensing either the front or rear circuit has a problem and is shutting it down. this leaves you with only half the brakes you should have. You either have a leak or air trapped in the line. Brake fluid absorbs moisture from the air and needs to be flushed and refilled every two years or so. The water boils at a much lower temp than the brake fluid,(not good). Flush & refill will probably cure the problem. Good luck, Lon.
90 RS Convertible
Owner: Top-Down Solutions
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Aug 16, 2001 | 12:11 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Fill the reservoir, pump the brakes a few times and look undernieth for and leaks.
I'd guess since you just changed the master that you didn't bench bleed it and now have air trapped in the lines.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
