What size tires should I run?
Old Aug 11, 2001 | 03:15 AM
notslow's Avatar
I have 7 x 17 and 8 x 17 Budniks. What would the best size be to run? There were 245-45-17 all around when I got it, but I want bigger on the rear. Any thoughts?
'89 GTA 350, edelbrock headers, 3" exhaust, Flowmaster muffler, Crane HI-6 ignition, cone filter, KYB AGX shocks and struts, urethane bushings and motor mounts, more on the way. My fast car is a '91 NSX, B&M adjustable fuel pressure regulator, Flowmaster exhaust, no cats, Cantrell Concepts Ram air system. Still love my GTA.
Old Aug 19, 2001 | 03:21 AM
notslow's Avatar
Come on, someone has to have an opinion on this. Does anyone know what size tire on a 17 x 8 rim will keep the speedometer correct? I was thinking 225\45\17 in front and 255\45\17 in the rear. Any thoughts?
Old Aug 19, 2001 | 08:23 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
Since its not the width, but the height of the tire that changes your speedo readings, you could go as wide as a 275 on the rear, if it'll clear everything. (and I'd think it would)
You're running a tire with a /45/ sidewall height on the front and the rear, so with a 7" wheel the 245 tire will work excellent in the front. (again if it clears everything) Otherwise the 225 up front.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Vintageracer
Jan 10, 2020 05:33 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
