wheres my brake fluid??
Old Sep 2, 2001 | 06:37 PM
john72ss's Avatar
resivour empty today!! pedal is soft too... no leaks at the wheels or at the master cyl..... whats up with this???/ help!!...... four wheel disc new pads... 85 z28 with 305/700r4......john
Old Sep 2, 2001 | 06:49 PM
R.O.B.'s Avatar
Possibility of the master cylinder is leakin in the rear, and going into the booster.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
48psi regulator, (Nickel method)
Old Sep 4, 2001 | 09:59 AM
87tpi420's Avatar
yep good possibility! be careful driving it. i had this happen to my f250 i would use about a quart a week it went into the booster and sucked into the motor. i dont know if it was good for it but i ended up junkin the truck shortly after. i would definately fix this as you will soon have a 3000 lb missle heading towards someone.
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
Old Sep 7, 2001 | 04:11 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I just fixed this; the bendix rebuild kit was $26, and the m/c was easy to rebuild. I swapped rear drum to rear disc last year, and had to get two rebuilt m/c's before i got a working one. I wasn't about to go thru the same hell again; that's why I rebuilt mine.
My rebuild info is here: https://www.thirdgen.org/messgboard/...ML/002560.html
The m/c kit info is here: https://www.thirdgen.org/messgboard/...ML/002625.html
Remember, the reservoir closest to the firewall is for your FRONT brakes... not for your rears. So when that rear reservoir is empty, you're just relying on your back brakes! Be safe...
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Sep 9, 2001 | 12:34 PM
john72ss's Avatar
thanks for the post guys!!... but i found the drivers side rear caliper was leaking.... did the job myself for 77 dollars...and now must bleed the system.......john
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
masonta
Sep 1, 2015 06:40 PM
