Traction devices for thirdgen
Old Sep 10, 2001 | 06:17 AM
NORT's Avatar
I have a 84 Z-28 and have been working on getting the most out of the 355ci. that is in it. I have the motor at about 375hp. at the flywheel so it should be right around 300 at the rear wheels. Now that I have some of the power that I have been looking for I have to get it to the ground! I have only been to the drag strip once sense I got the car where it is at right now, and it was boing quite a bit of wheel hoping on me which was not helping my 60ft. times. I know that there has to be a bunch of you folks out there that have or had the same problem as this and would realy like to here what you may have done about it. I know that there are some products out there that are made for the thirdgens but don't want to get something that isn't going to be of any help. I looked at some traction lift bars that Lakewood makes but just can't see what good thay could do when the rearend is set up like it is, it seems that with the torque arm that is on it would stop the axle windup if there is any. Anyway if one of you folks has any good sugestions as to what would work well please get back with me it would be greatly appreciated. Thanks NORT
Old Sep 10, 2001 | 12:24 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
LCA relocation brackets are the biggest bang for the buck; then LCAs themselves; then a stiffer torque arm that attaches to something other than the trans itself. SFCs will become a necessity once you start to hook up. The first 2 items should cost less than $250 installed.
ICON Motorsports
Old Sep 10, 2001 | 09:21 PM
98_1LE's Avatar
I beleive that drag radials are the best bang for the buck traction mod. You only need LCA relocation brackets if your car is lowered and the LCA is higher at the axle end compared the the frame end. The LCA should be horizontal, or parallel to the ground. That being said, tubular LCA's with stiff poly bushings will basically end deflection in these parts.
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Old Sep 10, 2001 | 10:26 PM
82camaro's Avatar
Car: 82 camaro SC
LCA relocation brackets help a stock height car. With a level LCA traction is good. But with the rear of the control arm lower and the front it plants the tires even harder. When I launch, the back end comes up, pushing the tires down into the pavement. I have 1.5 drop springs and 3.5 drop LCA brackets.
I would do the subframe connectors first.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Sep 12, 2001 | 02:33 AM
Jza's Avatar
Jza
<font face="Verdana, Arial" size="2">Originally posted by 98_1LE:
</font>
The LCA should actually be lower in the rear than in the front, not horizontal.
Terrell351
Jun 13, 2021 01:13 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
theurge
Aug 21, 2015 12:46 PM
